Mazda 2.2L \  nitrous on stock motor?
views 1028
replies 6
following 5
rotten   +1y
anyone sprayed thier truck before?... im not trying to be some quarter mile killer or a freeway racer, i just think a 25-50??? hp giggle gas button would be fun...
motor wil be stock with exception of a weber carb... .and i think imma mill the head down wen i pull it all apart to maybe git a bit more compression out of it.
is it dooable without melting holes in the pistons the second i push the button?
im jus thinkin an easy set up that goes into the carb along with the air.. (so sprayed from air filter lid pretty much)
winslow33   +1y
I wouldnt recommend it....
sparage   +1y
^ What he said.
rotten   +1y
heartbroken. lol.
v8xcab   +1y
Just bc u can, doesn't mean you should but I'm curious to see what happens! I think it should hold considering it's not a big shot. However, I do hope you are running a wet shot to keep from melting your pistons down as you previously stated. Fogger nozzle will do the trick
oo7bob   +1y
I have nitrous on my daily driver Dakota, 205000 miles on the clock. It is all about how you use it. I get about a 35hp increase from a dry shot in the end of the air filter, that with some cams and an intake I run 14.0 1/4's, prefect, then I dont have to wear a bucket, it messes up my mullet.
I just spray the nitrous, no additional fuel, but its on an injected motor, the o2 sensor catches the additional oxygen the nitrous creates and fattens up the fuel. If your planning on running a weber/carb, you will need to plumb both nitrous and fuel, the nitrous leans out the cylinder and creates higher pressure, = melted parts.
What happens most of the time when things are destroyed is from how easy you make more power. Change the jets, more power, just one more bigger, even better, okay, one more..... next thing you know, you have doubled the 80 horse that 2.2 makes, and it cant take it.
Do it, it's a total laugh. Try to stick to a reasonable shot, maybe 25, hell, that's just over a 30% increase.
rotten   +1y
yeah, really this all just sprouted from a used kit being offered for 150$, it got me thinking... like i said before, not trying to race or anything, but would be cool to have a 25hp button while cruisin down the freeway.... but then again, seems like more work than its worth ya know... i gotta worry about gettin the bish in the weeds first, so maybe ill come back to this in a few months when im done with the first part of my "project" haha
