Mazda 2.2L \  wiring.
wiring.
views 813
replies 3
f2tb2200   +1y
so pretty much im stumped on this wiring. i dont have an engine in the truck at the moment. but wanted to work on other things till i get my motor finished. i wanted to hook up my stereo/ gauges and other electrical accessories. but when i turn the key over there is no power to anything, no interior lights, nothing on the cluster comes on. not a peer. what all needs to be plugged in to run it. i checked all fuses.
axel breaker earl   +1y
The battery!
LOL.......I'm assuming you do have that hooked up!
If your negative battery cable is all stock, it should have a good ground to the passenger fender and doesn't need to have the end that grounds the engine in place for running the lights and stuff.
There is a under hood fuse block near the battery location.......make sure those are good (3 of them in there I believe) and the 80 amp main fuse is BOLTED in, so don't think you can pull it out......the other two you can.
Post was last edited on Jul 26, 2012 03:07. This post has been edited 1 times.
jenko   +1y
Also check your earth strap, feel along it if it's insulated to check for "soft/empty" spots.
f2tb2200   +1y
obviously i have a god damn battery in the truck. im not that retarded. i decided to take a different route. thanks.
