need some help real quick
bottemedout
1989 b2200, how do I remove timeing gear off of the crank? I have to replace my seal and Im down to the gear but caint get ot off. Is it suppose to slide off with a puller? If so what puller? My 3 jaw is to big
E
emjay
a little PB blaster and a lot of patience. One time I had to put the crank pulley back on the timing bolt, loosely (3 bolts, about 3-4 turns in,) and used the crank pulley like a slide hammer.
bottemedout
the "bolt" on the end of the crankshaft, does it come out or is it just there to use a socket to turn the crankshaft?
F
fuddy123
That big bolt has to come off. It's right-hand thread. Use an air wrench, or put the truck in 4th gear, put on the e-brake, and use a breaker bar with a socket. You might need a pipe on the end of the breaker bar for more leverage. Once the bolt is off, the gear should slide off easy. If not, a small claw bar should do it.
