Still no spark...
Still no spark...
W
westacles
What's up guys I'm having trouble getting spark in my 1993 B2200 2.2 carbureted 5 speed. 12v to the coil, and the coil and pickup coil ohm out correct. All ignition components are brand new. Now where do I go from here? Is there something between the ignition and the computer or anything I need to check. Maybe a bad computer? Any ideas will be a big help to solve this mystery. Thanks.
axel breaker earl's avatar
axel breaker earl
Welcome Westacles,
Did you replace the components inside the distributor? Not the rotor, but the internal electronic parts below the rotor?
Cusser's avatar
Cusser
West - you didn't pull out the distributor or loosen its clamp/timing, did you?
Actually, the real question might be: was the truck running OK, and then you did something, or did it just die and you're trying to get it running. Provide full details, helps us to help you.
W
westacles
The entire distributer has been replaced. And the timing is set correctly. The battery was crossed and I still got the truck to start and run after for about 5 minutes. After that it died and never started again. I feel like something got fried in the harness or something. Any ideas of what to check for?
sincitylocal's avatar
sincitylocal
Fuses and connectors are always something to check. They are notorious for developing corrosion and/or schmutz.
