RPMs raising when stopped
twitchvoodoo@gmail.com's avatar
twitchvoodoo's avatar
twitchvoodoo
hey guys i have a 1990 mazda b2200 2.2 five speed, fuel injected, extra cab. i had a question that maybe you guys could help me with on my truck... When i come to any type of stop my truck raises RPMs up to around 2000 RPMs. it somtimes goes back down to normal when im stopped long enough, but then if i step on the clutch or the break pedals it climbs back up. and then when i start to drive every thing is normal.. i have been checking my hoses for cracks or leaks and cant seem to find anything. some one mentioned to me may be its the break booster taking a dump? any help would be awesome thanks.
kovz's avatar
kovz
I was going to suggest a leaky vacuum hose. Take some carb spray and spray all the hoses while the truck is running. If the idle increases when you spray on a hose, it needs replaced.
fdugn545's avatar
fdugn545
I agree with Kovz here... Or another idea (and don't shoot me if I'm wrong) could it be a weak throttle return spring on the Throttle body. Idk what kind of spring the FI trucks used but I figure it's a pretty common problem with the carb vehicles I've dealt with.
Hope you get it figured out. I had this problem with my truck but it's carbed and I had vacuum leaks under the carb...
Hope this helps,
Fred
Sent from Samsung Galaxy S3 using Tapatalk 2
