Help 87 not sure whats happening.
E
ef9ross
OK here's the deal guys i have a 87 b2200 and i have completely rebuilt the bottom end with new pistons, rings, main and rod bearings wrist pins I installed a new oil pump, water pump, timing belt with kit, rear main seal. I put a brand new head with everything new cam, rockers, lifters, etc.. it have a new fuel pump Weber 32/36 and the cats are gutted accel coil, new ignition control module, ignition switch i mean the list goes on but here's the problem: I've checked all vacuum and it starts up and will stay on but it chugs the f*** out of my gas and it drives until about 2500 rpm then it starts to jerk like if it not getting fuel correctly or something I'm at a lost right now I'm kinda stumped any advice would be greatly appreciated.
I
inlinesicks
Check the carbs float level.
Cusser's avatar
Cusser
Check for fuel delivery, clogged fuel filter, rust/clogged fuel sock in tank.
fdugn545's avatar
fdugn545
I agree here. I'm assuming u have a new filter, if not don't even question it just buy a new one (they're only like 2-10 dollars) and try and find the clear ones so you can see if there's any rusty crap floating around in your fuel.
Fred
Sent from Samsung Galaxy S3 using Tapatalk 2
E
ef9ross
Cusser I haven't check the tank sock, but I bought a clear filter and its clean fuel no chucks. Inlinesicks I will check the float but I think that the carb is taking in alot of fuel when I looked inside the barrel the fuel is kinda just sitting there like it does know when to cut off.
I
inlinesicks
If the float is set too high it will constantly flood the engine with fuel.
E
ef9ross
OK I check the float and yes it was set high and on top of that the pump was pumping to almost 4 psi. Its adjusted now, time fix a few more things thanks for the input guys
