Mazda 2.2L \  Engine rebuild kits ?
views 846
replies 3
following 2
robzilla   +1y
Has anyone used any of the engine rebuild kits that online retailers sell? RockAuto.com sell some? Autopartswarehouse also has a kit by DNJ. Just looking for some feedback while I decide the route I want to go.
The current B I have I purchased with a hole in the block the guy threw a rod. I picked it up cheap. I picked up a used engine on Craigslist. It ran good at first then started to smoke. I though it was a head gasket. I started to take it apart for head gasket and found oil in two of the exhaust ports, leads me to believe its the rings. I was surprised because the smoke looked more white than blue.
Edited to remove rock auto in title.
robzilla   +1y
If anyone has used an engine rebuild kit, which one did you use and would you recommend?
94droptop   +1y
I'm planning on the dnj kit from rock auto as well. Seems to be a well put together kit
robzilla   +1y
I ended up getting a kit put together by the local machine shop that rebuilt the head and cleaned/tested/measured block. Most parts were ITM. Rings were Hastings. Bearings by Clevite. I got a re-ground crank as well. I re-used my pistons.
