Mazda 2.2L \  Secondary Air Hose Assembly
views 805
replies 3
clothier   +1y
I have a 1988 b2200, i was wondering if I could remove the seconary air hose assembly and the truck run ok. I think thats is what is called, its the three tubes in front of the breather and run to the manifold.
Cusser   +1y
Those seem to be called the PAIR tubes, and those with Weber aftermarket carburetors typically remove them, and use lug nuts 14mm x 1.5mm to cap off the four threaded outlets on the driver side. Like I've done.
richard93   +1y
I cut them off below the manifold pinched the ends and welded them shut but as cusser said you will have to upgrade ur carb to a weber or Holley ( rarely used) in order to remove them
charlesskelter   +1y
I removed them off my 86 B2000, used brass caps to cap off the manifold so it doesn't look so half done and I'm running the stock carb. I also removed the ECU and all associated BS. I had to tune the carb but that's to be expected.
