Factory Guage Swap - Single Speedometer to Dual Spedo & RPM?
kc_42599@yahoo.com's avatar
347 stroker's avatar
347 stroker
Hello, I've been contemplating what direction to take with my guages...
I currently have a '90 B2200 with a single speedometer guage cluster. I would like to know from anyone who has swapped to the factory dual speedometer & rpm guage cluster, on how easy of a conversion this was or any issues to consider if doing this swap.
Thanks.
E
emjay
All the information on this swap you will need:
sincitylocal's avatar
sincitylocal
And if you plan on swapping in a 347 stroker... there's a tachometer mod available too.
edit: just saw your swap thread... DOH!
347 stroker
Thank guys... and yeah it will be on the 347. I've been thinking about it and I like the functionality of having the factory guage cluster all fully operational, especially if I can have the tac in there as well... that way all I need is a few extra guages, and can just modify me a pillar guage pod if I can't find one..
Good looking out!
E
emjay
CRX gauge pod:
Fiberglassed, one extended because it was longer:
sanded and painted:
installed:
It's pretty easy to do, I had to go overboard because my EGT gauge was quite a bit longer than the other gauges I was using. You can also see where I put them under the vent. Others have used just the plastic one and molded it with a heat gun, I was not as successful.
sincitylocal
I swapped a small block Chevy into mine. It was killing me seeing my tach just sitting dead in the dash, taking up space, so I found a way to make it work. I wrote this one up myself, so don't be afraid to ask any questions you might have.
(or-V6)-Tachometer-Mod
347 stroker
Wow... Thanks!!! This gets better and better. So I don't even need to do any wiring modifications (unless I want the clock to work), and then Its as simple as a circuit board swap to get the proper tac signal for the V8... !
The hardest part will be finding me a decent tac gauge cluster for the Mazda, and a removing the cluster from the Bird...
NICE... Thanks!
sincitylocal
Glad to help.
