vibrations
vibrations
I
itfitz98
89 b2200
Ok so it started vibrating at around 45 mph and ends around 60 and balances out and i dont know where its coming from. Firat though was a tire out of balance so i swapped all 4 tire with the ones off my 83 and nothing changed.
It doesnt stop if i switch gears (thinking it may be rpm related)
It stops if i let my foot off the gas or get up over 60 mph.
Drive shaft and ujoints seem tight and there didnt seems to be any play in the carried bearing.
Thoughts?
sincitylocal's avatar
sincitylocal
Drive shaft bent or out of balance?
Put it up on jack stands and run it through the gears. Have a buddy check underneath when the vibration is present.
I shouldn't need to say this... but,
DO NOT GET UNDER THE TRUCK WHILE IT'S RUNNING LIKE THAT!!! Check from the side.
fdugn545's avatar
fdugn545
Sounds like a bad u joint to me. I second Sin on that idea. The best way to know for sure is to check it in real time. If it's a u joint though u can just lift the vehicle up on stands and just yank on the driveshaft. There's should be little to no movement if it moves u need u joints.
Sent from my SPH-L710 using Tapatalk
hos
Another thing you could check for on the driveline is a balancing weight that the weld came loose on. You would see a silhouette of where it used to be and maybe even an old spot weld. If the driveline doesn't turn up anything you might check the balance weights on your wheels. My wifes car threw one of the weights and the front end started shuttering so bad I thought I had a warped brake rotor.
I
itfitz98
I swapped the tires off my 83 just to make sure it wasnt that. I was really hoping that was it.
Im going to pull it in the garage tonight and see what i can find.
Aint never easy is it?
I
itfitz98
the carrier seems to have a handful of play in it. Ujoints are tight. how hard of a project is this? it looks like its just a nut on one of the shafts, drop it and replace.
I found one online from advanced for $31.
Will this one work?
*14925|L2*15051|L3*16343
I
itfitz98
just ordered the part from orielly's. it will be here saturday and was $26.99 plus tax. hopefully this will take care of that nasty vibration.
there goes my plans for doing the valve seals this weekend. I'll have to wait until next week for that one.
jc50942
just because u-joints are tight doesn't mean that they aren't bad, if they are dry and binding, that can also cause a vibration. Usually there is a squeak involved when this happens but not always.
I
itfitz98
no squeaking but with as loose as the carrier bearing was I'm fairly confident thats the problem. it will move a good 1/2 inch. So I guess my approach will be to replace that and take it from there.
it will shake the teeth out of your head.
