Mazda 2.2L \  carrier bearing
carrier bearing
views 851
replies 7
itfitz98   +1y
So im fixin to replace the carrier bearing and i need to know what size the nut on the driveshaft is. All i know at this point is that i dont have anything big enough. My 18mm was too small...not by much but im guessing 20-21 mm but not sure. I only want to buy one.
Cusser   +1y
Your wheel lug wrench is 21mm. Like your spark plug socket.
itfitz98   +1y
Ok...that was the wrong size. 21 is still too small.
bagged89mazda   +1y
its probably a 22mm.. if need be any of the advance auto parts /auto zones have a free tool loan program where you can barrow a tool to do the job .
itfitz98   +1y
It was a 26mm...
Now on to beating and cutting out the bad ujoints.
Cusser   +1y
Wow - never heard of anything being 26mm before....but I said similar before buying a 23mm socket for the differential plug...knew that 24mm and 7/8 inch were "too big"...
itfitz98   +1y
Ujoint is almost out. One more side to hit with the die grinder to get the middle loose then beat out the cups.
itfitz98   +1y
Be carefull when you beat things...they might just be looser than you think.
