Mazda 2.2L \  How to Remove Oil pan?
views 2553
replies 7
following 5
guppytruck   +1y
I have a rear wheel drive 1987 b2200 5 speed. 2.2L engine. I need to replace the oil pan gasket. Im using a Chilton for the procedure. Any experience doing this job?
Im hesitant on doing it because the cross member and a few other parts need to come off. The manual says "support engine at the crank shaft pulley"
To me that means put a jack under the pulley wheel to support the engine. I feel that could be wrong. That seems like a lot of strain and weight to be put on the pulley.
Has anyone removed oil pan for this model? suggestions?
emjay   +1y
Drop the cross member and steering linkage. I dont use the crank pulley, instead I use the transmission to support the motor.
Don't use a gasket! Use grey RTV silicone, factory manual instructions.
Post was last edited on Apr 06, 2014 05:04. This post has been edited 1 times.
guppytruck   +1y
Thank you so much! I will do that. Yes I have the Grey RTV silicone and from reading other posts here learned to use only that.
Cusser   +1y
I have removed my oil pan twice (1988 B2200), once to re-seal, and once during my rebuild. You need to remove one tie rod, or one steering linkage, plus the cross-member, gussets, etc. Hardest part was actually pounding the pan off !!
I also used Ultra Grey.
mazdatweaker_2   +1y
To break the seal on the pan I used to pound stubby screwdrivers with the flats ground down to chisel edges into the seam between pan and block. I never saw the need to support the engine. I would drop the center support and the two bolts holding the Pitman arm, allowing it to drop out of the way. Hope this helps.
befarrer   +1y
Why do you have to support the engine? The motor mounts are not removed so that point seems pointless.
Cusser   +1y
I didn't support the engine when I did this.
guppytruck   +1y
I did not need to support engine. Took off 1 side of cross member and pulled it down. Hardest part was taking off pan. I used a 2" putty knife. Job succesfull. Took a long time but well worth it. Saved $300 which is the cost to have a auto shop do it. Thanks for the support everyone.
