Mazda 2.2L \  where is the iac on a carbed 2.2?
views 727
replies 5
oonyong   +1y
I replaced my timing belt and water pump today and I had to turn the idle up a bit to adjust my timing to 6btdc. the truck is great timing wise, no variation or anything but it stumbles on acceleration and with what I have been doing to the truck I think I have iac dirty issues. the egr was gross when I removed it and blocked it off. is the iac easy to remove and clean up on a 2.2 carbed?
sincitylocal   +1y
IAC is EFI only.
oonyong   +1y
thank you.
mazdatweaker_2   +1y
When you adjust the timing on the engine you need to pinch off the vacuum advance, then set the base timing to 6 degrees at idle.
oonyong   +1y
o rly. ok thanks I didn't know you had to pinch off the vac advance.
dan woodland   +1y
Should be in any service manual and on the underside of the hood on a sticker.
