Mazda 2.2L \  Mazda b2200 not running right after head gasket
views 1239
replies 3
lucasfournier   +1y
Hi guys I have a 1988 mazda b2200. I blew a head gasket and then pulled it apart and did a timing belt water pump and head gasket. I put it back together and now I need to put a little gas in the carb to get it to fire up and once I do it idles very high and then I give it a little throttle and it goes down and tries to cut out and I have to give it more gas to keep it going. I am not sure whats wrong I feel like I might have missed doing something while hooking the intake back up. When I did it I just pilled the intake off and then pulled the manifold with the carb and everything attached. If anyone has any advice or ideas it would be greatly appreciated. Thanks
mazdatweaker_2   +1y
Check your cam timing. From your description it sounds like the cam is retarded one tooth.
lucasfournier   +1y
checked it again and it is spot on
geterdun   +1y
All things being aligned correctly, (crank, cam, distributor rotor to number one distributor terminal) sounds like a vacuum leak.
No one adjusted the curb idle, choke fast idle or carb. jet for any reason?
Does the engine have mechanical lifters?
