Oil leak
dwaredw44@gmail.com's avatar
Oil leak
alittlelow's avatar
alittlelow
I have a oil leak coming from the crankshaft the bolt is tight , I did install a new oil pump new waterpump timing belt truck runs fine but I can't seem to understand why oil is leaking from there any help would be appreciated thanks
Sent from my Desire HD using Tapatalk 2
Cusser's avatar
Cusser
There is a crankshaft oil seal. Has that ever been replaced? I had mine replaced at 60K timing belt changed (1988 B2200), still there at 203K.
FYI, there is also a camshaft oil seal, which is the same part number.
alittlelow's avatar
alittlelow
Thanks
mazdatweaker_2
You might want to replace your PCV valve if it hasn't been done recently. You shouldn't have any leaks from the oil pump since the seal was probably new when you replaced it. Pressure can build up inside the motor and if the PCV isn't working properly it creates pressure behind the engine oil seals. With the engine running, you can pull the dipstick and see if a piece of paper will stay vacuum stuck to the oil stick tube. The other thing to check is to see that the PCV hose pulls a good vacuum with the engine idling. Sometimes the line gets partially clogged and then vacuum into the engine isn't strong enough.
alittlelow's avatar
alittlelow
New pcv and I'm running a weber
mazdatweaker_2
Check the PCV hose where it goes into the intake manifold to make sure that the intake hole isn't coked up with carbon.
alittlelow's avatar
alittlelow
Ok will do thanks
