Mazda 2.2L \  1992 B2200 running rough
views 1893
replies 4
jaredo   +1y
Hey everyone.
This is my first post, so if I have posted this in the wrong section, or have not explained myself on any of the following let me know!
So, I have a 1992 Mazda B2200.
It's been running rough for the past couple of months.
It was idling very poorly
The truck is currently running on 3 out of 4 cylinders
The #2 cylinder is receiving spark, but upon pulling the spark plug wire off while running, there is no change in the idle. Yet pulling #1, 3, and 4's plug wires while running the truck will either die or idle extremely roughly.
We have tried;
- changing the distributor cap and rotor
- changing all spark plugs
- changing all spark plug wires
- adjusting the idle
- adjusting the timing
- tightening the valves to specs (0.007 on intake, 0.009 on exhaust)
So basically my truck is running on 3 out of 4 cylinders, and is idling very roughly.
dan woodland   +1y
Well I guess you have your answer, running on 25% of the cylinders will make it run rough.
Does this truck have an EFI or carb setup.
Did you check for vacuum leaks on the lines near #2?
jaredo   +1y
Haha, yes that is my problem.
But my question is why has this happened?
This truck is fuel injected.
I didn't notice a vacuum line designated to the #2 cylinder, but will have a look, thanks.
befarrer   +1y
Perform a compression check. If that is good, see if you can move the fuel injectors around, swap the #2 fuel injector with any other. If the dead cylinder follows the fuel injector, then the injector is plugged or otherwise not working, if it does not, it could be a wiring issue. If the compression is low in that cylinder, then there is some internal problem in the motor.
geterdun   +1y
Don't forget to check wiring harness voltage at the injector connector before moving injectors.
