ok i have a 91 b26i it starts up runs fine for 2 seconds the idles like it has huge cam then dies. i unplugged the white connecter that runs by the iacv i unplugged the white an it ran the same. i unplug the black and ran worse. then unplug both didnt run at all. i unplugged my maf while runnin an ran the same. i already replaced it 3years ago. can someone give me some insite on where/ how i can test to see if the maf and or the iacv is bad. thanks lmk
bagged89mazda
you may want to contact Kyris6 on Mazdatruckin.com he's a mazda motor Nut (and i mean it in a good way) he maybe able to steer you in the right direction .
9B
91 b2600i
aight thanks man
smcustoms
comp might not be reading mass. got some parts if needed
beatmymini
my truck does that and its the iac. they just get filled with junk and get clogged. i would suggest trying to clean it out with brake clean or finding on at the junk yard cause they are a little pricey brand new.
9B
91 b2600i
i cleaned the maf,iacv an still ran the same. i did the self diognostic test an no luck. so idk. i found an iacv for like 40 on ebay, a maf for like a bill maybe. so idk
