Mazda 2.6L \  cranks no fire
cranks no fire
Mazda 2.6L Mazda Engine Mazda Tech
views 938
replies 1
following 2
newb2600i   +1y
ok so im new here this my second mazda its cranking and fuel pumps on.i was told its my distibutor bad i had guy look at it but he took all the guts outta my distibutor cause he said its bad this sound right it has been sitting due to building back half like said fuel pumps on no fire tho any one else had put new distibutor in to get truck running im prayin thats all it is
crush   +1y
JUNK YARDS USUALLY HAVE THEM. BE SURE YOU GET THE EXACT ONE. THERE ARE 2 TYPES FOR THE MAZDAS, ELECTRIC AND MECHANICAL. IF YOURS IS MECHANICAL BE SURE YOU INSTALL IT CORRECTLY. REMOVE YOUR VALVE COVER, AND FIND TOP DEAD CENTER ON YOUR # 1 CYLINDER, THEN CHANGE OUT THE O-RINGS ON THE DISTRIBUTER, AND INSTALL INTO THE ENGINE WITH ALL THE MARKS LINED UP. PUT EVERYTHING BACK TOGETHER AND HAVE SOMEONE CRANK YOUR ENGINE UNTIL IT FIRES, THEN ADVANCE YOUR DISTRIBUTER UNTIL IT IS RUNNING THE WAY IT SHOULD. HOPE THIS HELPS YA
