Mazda 2.6L \  Help...90 b2600i running rough....HELP PLEASE
Mazda 2.6L Mazda Engine Mazda Tech
views 1729
replies 3
following 2
kev6772   +1y
Step daughter has a 90 b2600i that is missing on cylinder 2. I have replaced the plugs, wires, cap, rotor, and injector. I got a reman ecm from oreillys and that didnt change anything. Before I did all that it was missing on both front cylinders. The miss will go away while driving but only for a second or two. I'm lost, please help....thanks
midnightmike   +1y
maybe one of the valves aren't fully closing, do a compression test and see what it shows, could also be a cracked head
good luck
kev6772   +1y
Sorry forgot to say that I pulled the head and had it checked and it checked out fine. I did a compression check and it was 150+ not to say it hasn't changed but it should be good enough it would fire.
kev6772   +1y
Problem solved....just because you buy new injectors does not mean they are good...lol found one to be bad.
