Computer Swap
Computer Swap
hitdogg
Hey guys, got a question for some of you guys that may have tried this before. I have 2 B2600i's. One 4wd one 2wd, different year models. I'm pretty sure that the computers have the 2 yellow connectors.
I read somewhere, I think it was even posted by Axel, that a repaired computer may not get as good of gas mileage as others. My 4wd gets terrible mileage, I get about 160 miles to a tank, which is about 15mpg. My 2wd on the other had gets about 240-260 miles to the tank which is about 21-22 mpg. I was thinking about swapping the computers for a tank, just to see if I could get more mileage out of the 4wd. Will I hurt anything in the computers? Does it matter is one is 4wd and one is 2wd? They are both 5 speeds.
I know a 4wd typically gets a few less mpg's thatn a 2wd, but I would at least hope to get 200 miles out of a tank.
Any opinions are welcomed
gandrimp
My truck with the winter fuel is getting just under 19 mpg, summer time it gets over 20. 93 4x4 5 spd
I see no reason you couldnt swap the computer.
hitdogg
Well swapped the computers. The 4X4 isn't getting the gas mileage that I had hoped, but man it is running very good. I do know that I am losing some mileage on my tripometer because I have 31X10.50's on there. Now on the other hand, the computer that I put in my 2wd truck, gets very bad gas mileage. Very bad! I went from 240 to 260 miles on a tank to probably just a little over 200 miles on this current tank. So, I guess I need to hunt a computer.
cab+rider
That is an interesting result. On your 4X4 truck did you clean the spark plugs after the swap out? I assume both are EFI systems.
hitdogg
No I didn't clean the plugs. I may try that. I did put the timing light on both. I know I have read a thead by Axel Breaker Earl, where sometimes the computer repair places just get them fixed to make the truck run. I was wondering if there was any hope for the computer? Or do I need to hunt one. I haven't took the cover off to see if any of the traces are shot. Oh yeah, filled the 2wd up, and didn't even get 200 miles out of the tank.
E
emjay
try sourcing out an ecu from a 4 cyl MPV. 90-93 should be the ones with the 2 connectors. the 89 has 3 connectors.
axel breaker earl's avatar
axel breaker earl
That is good to know HitDogg!
I know that I had a similar experience when I changed the computer in mine after getting bad mileage, but with you having 2 trucks and knowing what they've been getting in MPG then swapping and getting worse, that underlines my discovery also! I would love to put a MegaSquirt or similar in my truck so I could play with the settings and see what kind of mileage I could get out of these trucks.
Thanks for posting your findings on this!
hitdogg
Mega Squirt huh? Very interesting. How much are those setups? A rebuilt computer from just about any parts house is 4 to 500 bucks. How easy are they to set up? Has anybody ever set one up on a 2600i?
