Coil swap help
Coil swap help
that.minitrucker
I've got a new Accel Super coil I wanna put on my truck old one is cracked and arking out. Anyone know how to rewire the 4 wires off stock coil to a after market coil trucks a 89' b2600i
cab+rider
Got any pics of both coils? Thinking out loud here is the original coil marked with the + or - symbols next to the connection points?
Also does the original have the external ballast resistor mounted with it as well? Does your new coil mention with internal or external ballast, most older versions of after market coils indicate this?
that.minitrucker
Stock coil had no markings
After market did and instructions only mentioned ballast for points setup. I got the coils swapped out and truck lost the miss it had seems to run a lot better now
jacob_tamblin
How did you rewire the 4 wires to a 2 wire coil??
cab+rider
Here is a site with some wiring schematics to compare with your OEM coil.
Another question what are the colors of coil's wiring?
Do you have any pictures of the OEM coil?
