torsion lift reverse of drop ?
bubonik
Hello
I have been looking into how to lift the truck more then the 3" body lift i have currently
i saw a bunch of right ups on how to lower the truck with the torsion bars
can i do the opposite to give it lift instead ?
any problems i might encounter ?
slamsonthedawgmaster's avatar
You can go up with them but not too much.. there really isn't a good way to lift the front unless you do a solid axle conversion.. I turned mine way up till the upper bumpstops almost touch and it lifted it nice but I had to drop down the front diff due to shaft binding alittle at full extension..but after that to go any higher I gotta solid axle it..
bubonik
how much did that get you ?
do you have pics on the diff lower ?
It got me about 3-4 inches and I'll throw the truck up on the lift and snap some picks for you.. I have a stock one up there now..I'll snap pics of that one too so you can see the difference
bubonik
wow 3-4 ?!
i was hoping to get 2 so this sounds like it could work !
I'm looking forward to pictures
what would i need to do to counter tire wear ?
shims ? remove shims ?
I'll definitely get the pics up for you..and I just had a good alignment done after I raised it.. no alignment problems or wear issues.. its still within the factory travel so it holds alignment good
bubonik
Don't forget those pictures man
Didn't forget! Lol.. just been working my butt off and haven't had a chance to get under my truck... should be able to hook you up on Monday
bubonik
Did you manage to get pictures ?
No pressure
I won't be doing this right away anyway
Thanks !
Lol.. I'm trying man!.. had a damn saab stuck on my lift since Monday morning.. its sucks waiting on parts
Related Discussions in Mazda Lifting Static
