New leaf springs? - '86 B2000
ridin
Hi all. My leaf springs are pretty flat. I see the bog-standard option runs about $300 the pair: " target="_blank
Is there a slight upgrade that costs a little more but delivers more capacity? I.e., WeGotYerTruckSprings.com sells an aftermarket set for $330 which is, I don't know, 2" higher or gives $250 lbs more weight capacity?
Or,
Is there a cheaper option for regular leaf springs that I could check out?
Thanks for your suggestions--Mike.
spacemonkee23's avatar
spacemonkee23
add a leaf or maybe add some spring helpers?
Mine are very flat also but I have a camper and full bed interior in mine, I may add some spring helpers for the time being.
**Edit did research on re-arching springs... Heating method - not cost effective, Cold method - doesn't last long before they sag again.
chaserjohndoe's avatar
chaserjohndoe
Don't do add a leafs make your truck ride super hard. I would do a set of coil spring between the leafs and frame. In the Toyota world it's called a "zuk" mod. Google that and you will get the idea. or if you are looking for something not so redneck/cheap air shocks also work.
ridin
Thanks guys! That zuk mod looks pretty interesting. I wonder how you figure out what spring to buy?
And yeah...redneck works A-OK for me...
EDIT: Actually maybe no...the ZUK mods seem to be oriented to the 4Runner which has a bump stop on the frame. My B2000 doesn't. I guess I'd need to have something welded onto the frame in order for the top of the coil to stay put?
Below...my truck, with a naked, bump-less frame
beardguy
How about coil spring kits? I have a pair on mine, work well enough for the prices. It won't give you increased load capacity with bad leaf springs, but my leaf springs are flat and this helps the ride a lot, lifted it 2".
https://www.autozone.com/suspension-steering-tire-and-wheel/leaf-spring-assist-kit/superior-automotive-leaf-spring-assist-kit/975039_0_0
Related Discussions in Mazda Lifting Static
