Mazda Adjustable Suspension \  new balljoint holdin frame up 1/4 inch
Mazda Adjustable Suspension Mazda Suspension Mazda Tech
views 966
replies 5
bagged2.2   +1y
replaced left side bj and now its like it wants to hold the truck up a little bit...driver side lays rocker but passenger wants to stay up.if i stand inside the truck on the passenger side it drops...lmao. wtf do i do? is the only option pie cutting???
hunterw   +1y
Hmmmm I take it they aren't the same ball joints as far as brandd goes? Id try and match them first and if they are the same maybe the new one is just really stiff? Id pie cut the uppers anyway...
mazdaman82   +1y
plus the old one may be wore out more and gives more go ahead and replace it too... then pie cut them arms
bagged2.2   +1y
yea they look a lil different . and im sure the old one is worn and the new one is mad stiff... any good advice on the pie cut process before i go at it? haha
hunterw   +1y
When mine were done we cut the pie out of the side and the made a light cut on top..then put them back on the truck and layed it out.....then welded and plated thenn in.
bagged2.2   +1y
when you lay it out the naturally bend where you want them? how much material did you "pie" out
