Mazda Adjustable Suspension \  need help
need help
Mazda Adjustable Suspension Mazda Suspension Mazda Tech
views 1554
replies 10
following 6
dropn-mazdawgs   +1y
when i 4 link my single cab mazda will i have to move my gas tank some were else
baha   +1y
That depends on where you mount your link bars lol
blackhulk   +1y
do an off Y 3 link...
blackhulk   +1y
u could also do a forward 4 link and move the gas tank to were the spare tire used to sit...
dropn-mazdawgs   +1y
well i wanted to do a reverse 4link but i dno if i have to move it i just wanna move it up a little im trying not to move it
91extcab   +1y
generally a 4link setup runs right thru where the tank sits... if you bought new gas line tubing you could put the tank in the bed at the cab and run the 4link like normal. i've heard problems with running it as a reverse 4link...
dropn-mazdawgs   +1y
ok thanks
paparoach1983   +1y
leland there is speckulation on a reverse four link not working and working as long as its engineered correctly anything will work.
dropn-mazdawgs   +1y
hey roach is yours a reverse link
91extcab   +1y
true... but unless you really know your geometry or you really research into it, someone who hasnt done it before probably shouldnt make it their first attempt....
