Mazda Adjustable Suspension \  Need some Airbag help
Mazda Adjustable Suspension Mazda Suspension Mazda Tech
views 801
replies 1
following 2
lowlyfe   +1y
Alright so I am currently helping my brother bag the front of his 89 MazdaB2200 and ive got a couple of questions regarding the bag placement up front.
He's running a full set of Cando control arms and we notched the frame in order to run 7" slams. We got the bag placed so that it clears everything with about 10.5" of suspension travel which the fender will clear his 20's with about 2.5" of gap but the suspension will not lock up and will allow the upper arm to push into the bag if we do not limit the travel. **note that this is only mocked up and with a max of 130 PSI in the bag with the truck on jack stands.**
Which leads me to question the difference bewteen the bag being aired up on the jack stands and the bag being aired up with the wheels on the ground. Will we even see this kind of travel with weight on the suspension or not?
The way it sits right now tells me it would be ok to weld everything up and add a shock to limit the lift since there seems to be plenty to clear his 20's but I need a little advice before doing so.
Please helpa guy out if you can, it would be greatly appreciated.
tucknrimmaz   +1y
AS long as your sure it lays your good. After its all done then check the pressure to stop at so nothing rubs. You will see that travel it will just take more pressure to get it there.
