diff. swap?
diff. swap?
cgd2200
my question is wat diffs. are compatible with the b2200? i had bought anther rearend that has a locker,looks abt the same..
sincitylocal's avatar
sincitylocal
All of them are compatible, with varying degrees of modification.
The only ones that are direct replacement are from like trucks. ie: 2000, 2200, 2600.
cgd2200
all i know is it came out of a setup sr20det 1970 nissan deluxe.the bolt pattern on the diff housing looks the same.
jenko
if you have it in your hands, start pulling and see what's what
Otherwise sin's right.
I hear you guys don't have much in the way of LSD diffs?
The most popular conversion it seems is fitting an RX7 diff etc back there.
if you do the whole lot you can have an lsd, rotors and 5 studs. if you're really adventurous you can have IRS too!
(search and you will find)
cgd2200
epic fail, picked it up all lokked great, get home and its not an lsd sum shmuck jus welded the spider gears
ogrits
Hey hows it going? I'm Nate,
I'm new to B Scene But I picked up a Spare rear end, and a clutch lsd and ring and pinion off of a 84-85 mazda rx7.
All the splines lined up perfectly, it bolted into my spare rear end. I have a 1987 b2000 Btw. I heard that the rx7 Transmissions are compatible too. But I'm tight on money even though I have a spare b and rx7 tranny. But once I figure out what needs to be done I'll let ya know! Def check out that year lsd Though!
Related Discussions in Mazda Engine Performance
