magnum head question
rotten
I can't find a good answer..... there's a magnum valve cover on a dawg at my local j.y is there a way to tell if its a magnum head too? And second question if it is a magnum head is it worth getting? What's the difference?
fdugn545's avatar
fdugn545
I too would like to know the difference
rotten
Hers the head... it had a magnum valve cover but I was under the impression that if is a magnum it shouldn't have egrports in the intake part of the head. I'm assuming this has egr ports. Has solid lifters too.
rotten
Does anyone have a head off I could see some pictures of see if there's any difrense
hocbj23
MAGNUM valve covers will fit any 2000/2200 motor. I have an original MAGNUM cover which is black matte finish with white wire looms.The Magnum engine was JDM only with very little export and if so was to Asian countries and not USA.Found primarily in the Bongo series mini vans and a few other variants.They were usually turboed so had lower compression ratios vs. stock engines.If u found the head in a USA truck,doubt it is a for real Magnum engine,but if so,I would buy the whole damn thing as they are very rare.bj
Related Discussions in Mazda Engine Performance
