Mazda Engine Performance \  32/36 weber help
32/36 weber help
Mazda Engine Performance Mazda Engine Mazda Tech
views 1120
replies 6
alpha   +1y
just scored a 32/36 weber for 71 bucks on ebay... now i gotta get the adapter plates w/gaskets, manual choke cable, and linkage...
just wanna know if there is anything else i need to get to throw this carb on my 89 b2200....your help is appreciated!!!
89mazdalade   +1y
good score just seen on ebay they got the mazda adapter plates and gaskets dont remember how much though
alpha   +1y
i believe it was like 24 bucks
alpha   +1y
so is that pretty much all i need guys?
89mazdalade   +1y
i bought my carb as a kit but sounds like thats all ur needing the carb air cleaner filter gaskets and adapter plates i had to buy a longer accelerator cable autozone has the steel braided universal ones worked for me
89mazdalade   +1y
ohh u'll need to remove stock carb studs from intake and make sure when u get the adapter plate that it has the four allen counter sink head bolts to bolt the plate down and install new carb studs in the adapter plate good to go
Cusser   +1y
On my '88 B2200, the stock cable works just fine (Redline Weber K675 kit, anout 6 years ago). search and I've posted my Weber install tips I have posted a few times. You'll likely need a stronger return spring.
Ace Hardware has those countersunk metric screws with allen heads, at least the one 400 yds from me does.
