can i use the stock temp sensor with this?
highroller0439@aol.com's avatar
89mazdalade's avatar
89mazdalade
i found this on e-bay just wondering if i could use the stock temp sensor with this i know it comes with one but i donno if it will fit anyone??? thanks
91extcab's avatar
91extcab
why not use the sensor that comes with it...?
un4givn85's avatar
un4givn85
slightly off-topic but why do temp sensors have a minimum temp of 100? anyone know?
tucknrimmaz's avatar
tucknrimmaz
Maybe. You need to get the specs for the gauge sender. I would just use the one that comes with it and stick it in the intake manifold thats got the square plug in it. You will prolly need an adaptor like I did. A min temp of 100 because its pointless to go any lower. If its 75 degrees outside you are almost there.
89mazdalade
just donno if it the one that comes in the kit would fit says sensor mounting thread is NPT 1/8"
9
91_2600i
Just figure out what your current sensor is and then get an appropriate adapter if it's not 1/8 NPT.
Related Discussions in Mazda Engine Performance
