Help
peppy121
my question is can i take off stock carb and put a relgutor carb on it and if not what will i have to do to get it to run ?
chaserjohndoe's avatar
chaserjohndoe
whats a relguter card? and if you meant regular then, no. for our old mazda's the only way to go is weber, unless you want to do a bunch of fabbing to get, let's say a holley or similiar to work.
peppy121
sorry cant spell and i would very much like to put a holley on it so what would i have to do?
peppy121
and sorry i did not put on what madza i have so i have a 1987 madza b2200 4x2 and it has a a in-line 4 2.2 ohc with a manuel 5 speed attached too it and yes it is stock for now but will chagne soon
chaserjohndoe
Weber is about the only way to go. Our engines only make about 130 hp max, so putting a Holley would over carb it. I picked up my Weber for about $225 and it installed and running in about 2.5 hrs.
peppy121
okay - why would it take 2 and a hours to get it to run ?
mazdafvr
probly because you gotta remove the old carb and all the b.s. that comes with it, then u gotta put all the adapter plates together and install the new carb, throttle cable bracket and all. then u gotta tune it. you might can do it in less time, but that's about how long it took me, I took my time and a break or two.
Cusser's avatar
Cusser
Also check the Weber adapter plates for absolute flatness, sand them on a plate of glass with wet/dry, to avoid vacuum leaks.
peppy121
okay so petty much it a bolt on thing?
mazdafvr
yep, as long as u get the kit, comes with adapter plates and gaskets and everything else you will need
Related Discussions in Mazda Engine Performance
