weber install ?
weber install ?
ghettogrady88
i have a 87 b2000 i know how to install the weber but not sure what all i can delete as in vac lines an wiring i dont need?
h2omelon(nick)'s avatar
h2omelon(nick)
The only vacuum line you will need is the vacuum advance line from the distributor.The rest of this can go in the trash.
ghettogrady88
What bout o2 wire harness an ecu?
X
xxchromeghostxx
ecu can be removed completely if you want i have pictures of removing mine.
Cusser's avatar
Cusser
You don't need those. I still have the O2 sensor installed in my exhaust manifold with my Weber, this way I don't have to worry about ruing the threads in the manifold or plugging it up again, I let the O2 sensor be the seal. It's just not plugged in. And my ECU is still in place, just the connectors on the passenger firewall are all taped up.
mx_wrench's avatar
mx_wrench
Are you guys running the manual choke or electric?
benjimanactivate
did you guys trash can the charcoal canister too?
Cusser's avatar
Cusser
I kept the charcoal canister with mine. I made an EGR block off plate too. I also added a stronger return spring. See my list of other Weber install hints, do a search here.
Related Discussions in Mazda Engine Performance
