weber
Z
z2000
Which weber should i buy for 1987 mazda b2000? I am wanting to order it now haha. Thank you in advanve
chaserjohndoe's avatar
chaserjohndoe
32/36 directly from redline.
Z
z2000
Thats the one i ordered! Off of ebay should be here wednesday. How difficult is the install? Im ordering the header on monday! What dis you ise to block off all of the vacuume lines?
chaserjohndoe
Install was pretty easy. Took a couple hours. I used vacuum caps, but I plan to trim them all off. Like Tuna did.
I'm going to run the factory manifold into 2.25 pipe into a cat, then glass-pack, then a super 44. Not going to run the pre-cat at all. Pipe straight from the manifold.
If you have question ask. I will say look at Cusser's build and do like he did with the adapters.
Z
z2000
Thanks for all of your help man!
Related Discussions in Mazda Engine Performance
