18x8 rims
F
18x8 rims
laid_out_b22
Hey guys im having a hard time finding rims for my 89 b2200 I have 2wd sheet metal no body drop. I would like to keep the 6 lug and I currently have 17 eskies. I found a set of rims that im going to get if they will tuck. The front are 18x8 +40 and the ones in the back will be 20x8 +48 offset. The middle is blank so I can get them drilled to the pattern I need. Will these tuck with no problems?
mazdaman82's avatar
mazdaman82
fronts yes...back yes but will be close, may want to trim the lip to be safe
laid_out_b22
Ok the lip to the outside fender? Also in the rear it should sit alittle further in than the navi rims right? And last question will I have a issue with the innerpart of the bed? Once I buy and drill they are mine so just making sure I know the hieght of a 18 is like a half inch taller than my 17 eskies with 205 40 17 and the 18 having a 21535r18 but the 20 is 2 inches taller overall with a 30 series than the 17 overall will I have a issue with the hieght
Related Discussions in Mazda Wheels Tires
