Mazda Wheels Tires \  offset
offset
Mazda Wheels Tires Mazda Tech
views 1354
replies 5
following 6
bpete91379   +1y
What offset do i need for 20's for them to tuck? Can anyone help me?
jayeemo   +1y
google dude i seen it there
baha   +1y
That's a really vague question, do you understand back spacing and offset? The best answer I can give is to measure your truck and see. There are a lot of factors that impact what offset you need.
-2wd or 4wd front fenders
-Variation in manufacturing
-Drop Spindles or Factory
-Tire Width
-Wheel Width
newb2600i   +1y
im in same boat as u i was wondering the same
jchristian   +1y
I had the same question too..
i have 4wd fenders
drop spindles
215 or 225 or the smallest i need to go for tire width
wheel width 8.5.
hunterw   +1y
Ok ..I'll try and help. If you have 4x4 metal...in the front you can fit a 20x8.5 +31mm with drop spindles and pie cut uppers.but they will rukb bedsides in the rear. I think the backspacings is 6.25. I'm order to fit 20x8.5s in the front and rear you need somewhere around a +42mm or close to a 6 inch backspacing. I ran 225/30r20 tires. And you will have to alter the firewall some. For the tires to clear. I used a 2x4 and lowered the truck with the 2x4 in and it made some clearance. Amd the clutch cylinder is close to hitting
