18"x8 w/+25mm ofset HELP haha
rotten
like the title says, i found a set of titan steelies local for dirt cheap.... im assuming there narrower than the alum ones but not sure, anyone have any experence w/ these on bags and 2wd metal?
sorry guys but i cant find shit for an answer, w/ +25mm offset on 8" wide wheel, will they tuck on 2wd metal?
rotten
5.48" backspace w/ 25mm offset on the 18x8
5.46" backspace w/ 31mm offset(on eskies witch do tuck)
Am I correct in thinking that the said 18x8 will only stick out---.02mm more than the eskies? Meaning it will be tight, but should tuck
hunterw's avatar
hunterw
Boy thats close. Kinda sucks because you cant mill anything off the steelies either. Ive seen people tuck the alum 18x8 titan rims so i would think these would fit. If you really wantes them im sure an axle swap to a 720 or newer pup rear would dothe trick. I bet they tuck up front. I dont have a definite answer though
rotten
And sense its steel I wonder if the mounting surface is thinner. Thus helping my cause. I only want em cause I have yet to see em on a dawg. Only on a static hardbody..
Related Discussions in Mazda Wheels Tires
