Mazda Wheels Tires \  15" Nissan wheels
15" Nissan wheels
Mazda Wheels Tires Mazda Tech
views 1244
replies 4
jmll   +1y
Just picked up a set of 15" 1995 Nissan 4x4 truck wheels. I know the wheel fits but what size tire should i go with?
ulrich   +1y
I run 215/65/15s on my Mitsubishi rims. Tread diameter is within one percent of stock 205/75/14, so no speedo error, or gearing issues.
badchicn (rick)   +1y
If you are planning on a slammed look, 195-50-15's are the mini truck standard. Zero clearance issues. As Ulrich mentioned, with the reduced sidewall height, your speedo will be off.
ulrich   +1y
Handy tire calculator:
" target="_blank" target="_blank" target="_blank
My tires fill the wheel well. perhaps the Montero rim's offset isn't quite right, but I don't think I could get away with going lower than the current 2" drop.
What 215/65-15 tires, on Mitsubishi Montero rims may look like.
Post was last edited on Jan 31, 2012 02:01. This post has been edited 1 times.
steve@az   +1y
Here's mine with 195/50/15's on the rear, speedo is off though. Wheels are Mitsu Montero.
