Mazda Wheels Tires \  will these fit?? thanks :)
Mazda Wheels Tires Mazda Tech
views 1124
replies 6
cms062407   +1y
hey all,
will these wheels fit on a 1987 b2000, 4x2.
thanks!
" target="_blank
mazdamn   +1y
no. lug pattern is a hair smaller.
jc50942   +1y
seems to me that there is a guy on here somewhere that sells redrilled front hubs and axles with the ford bolt pattern...maybe it was on mazda trucking...cant remember....personally..i swithced mine to 5x4.5...soooooooo many more options.
cms062407   +1y
dang, okay! thanks guys!
how about these then????
" target="_blank
the are 2007 fj cruiser wheels....i think they should be a direct fit without having to grind or anything, right?
they are the same lug pattern, bore size and stud size....
jc50942   +1y
they should fit...maybe do some research to be sure on the center bore size and you should be ok...but you may also need the stock style lug nuts for those wheels...if im not mistaken, those use a shank style lug nut.
cms062407   +1y
im just going from this site, i found the site from a sticky post over at mazdatrucking.
I am just looking for wheels that will bolt right up, i dont want to have to do any modifications to the wheels or my truck.
blaz4wd   +1y
I did the same conversion. On my mazda. What are your specs on the rims you are useing.
