Mazda Projects \  Bench or Buckets
Bench or Buckets
Mazda Projects
views 1692
replies 8
following 7
mazdarat   +1y
Should i get me bench seat redone and looking like new or should I go for bucket seats. If i do buckets what kind of car bucket seats would fit just right?
oneslammedbseries   +1y
most honda seats will bolt up with little to no modification i had a set of s2000 seats in mine for a little while then decided to go with a factory bench seat out of a single cab no im trading the bench for a set of factory buckts but i also have a set of prelude seats i may put in it to but honestly with little modification you can put whatever seats you want in your B
Cusser   +1y
The B2200 bucket seats fit my ass just fine, comfortable. I'm 69 inches, 180 pounds.
Hey - just found out last weekend that my 2004 Frontier has tilt steering wheel. But I use the default/highest or the wheel blocks the speedometer readings.
the stock seats to me arent very comfortable i like the way the bench seat looks but there is no option to lean it back any and i would rather have a center console flow from the dash to the box in the extended cab
mazdarat   +1y
So like a Civic or a crx bucket will bolt up just fine
91extcab   +1y
Second gen rx7 seats bolt onto b series rails with very little modification...
mazdamn   +1y
Most toyota buckets use 3 holes of our 4. I had MR2 buckets in my old 88 cab plus. Was a fine seat.
A close buddy had some buckets from a nissan car. I dont remember the model, wasnt a 300zx tho. They bolted in the same.
The buckets I have in my current Maz are literally ON the floor. Damn they sit LOW!
oldmansmazdab22   +1y
Got my buckets out of a Mazda 323 (early 90's?) from the local Pull-your-part. Pulled the runners off a set of the factory buckets in a wrecked B, bolted them on and dropped them in. Cheaper then having the the bench re-done and I got lucky.. the color matched.
bigwills12ab2000ny   +1y
Nice! Good find...I wish I was that lucky haha I can't find anything local for cheap
