Mazda Projects \  i know we got a few ford gurus here. need your help
Mazda Projects
views 991
replies 1
following 2
xxchromeghostxx   +1y
Okay i was helping a friend wire his starter in on a 98 f150, as per him.i attached the wires where they should have went. After doing so we attached batterues neg terminal and sparks started flying and smoke came out of a ground attached from manifold to fire wall. Almost melted ground terminal to the battery!
So after this i removed alk wires got diagram an wired it correctly. Starter spins and engages, but the motor doesnt turn over, all lights radio etc work. Would this be a bad starter relay? Or a fusable link? I know this is mazda but i want help from anywhere i can get it. The engine is a 5.4 triton. Thanks for any help.
Oh we tried replacing tge braided line ground but no go there
robert_paulsen   +1y
check your fuses even the weird looking ones i had a 20$ fuse go out on a car when i was 18 cause i placed the battery back in the wrong way and wired it as such. good luck but seriously id check all fuses and then try relays
