rear end gasket
rear end gasket
chrismp91
my b2200 is leaking arond the seal of the rear end ware the head bolts together does anyone know how i could repair that? i cant find a gasket anyware
Cusser's avatar
Cusser
I'm having trouble understanding this post. If you mean that the engine has a leak at its rear, I'd make sure to check that it's not actually the base of the mechanical fuel pump that's leaking (rear of engine, passenger side).
Rear end typically refers to a differential, but there's no ""head" there.
jenko
or it's the tappet cover gasket and it's leaking down the head. post a picture up buddy
chrismp91
imtalking ware the hogs head bolts...like if u was gona change ur inner guts in ur rear end that seal broke and is seeping and the bottom of my rear end tword the drain bolt area is staying wet and just enought to notice it no major or even small drips on the floor at night
sincitylocal's avatar
sincitylocal
WTF? I can't understand either.
Hogs Head Bolts? I've been working on cars for 30 years and never heard of those.
sfls1's avatar
sfls1
The gentleman is referring to the rear end. People in the south call it a hog, and i will never know why.
To remove the diff you have to put the truck in the air, remove rear brake lines going to both sides, pull drain bolt on bottom, remove the 4 bolts on the back of the backing plate, slide them out, i would suggest putting new axle tube seals in, when i put the LSD in out of 84 rx7 i put new seals in and slid the axle in and out too many times and had to put a new seal in a month later, once you get the axles out, drop the drive shaft off the diff, and remove the bolts. it may be a pain to remove, but if you take a hammer and tap on the housing and spin the diff it will come right out, they do not make a gasket for it but ultra grey or black will seal it up just fine. i would suggest pulling it all the way out and cleaning the housing in the inside, clean the surface, apply a thin amount of silicone, you dont need much, just enough to cover the metal so you dont see the shiny metal anymore. slap it in fill it up,
recommended tool list would be INNER rear end seals, (there are an inner and outer but outer means pressing bearings off the shaft) 75w90 gear lube, i think its 2 quarts. brake fluid, silicone, and about an hours time. i do it for a living so i do it pretty quick, it may take longer if first time doing so.
cheers!
jenko
lol! thankfully someone speaks the lingo!
great post!
sfls1's avatar
sfls1
Here in the south we have our own dictionary!
example
"fixin" has 3 meanings. 1 a side dish at dinner. 2 actually fixing somethin and 3 about to do somethin. (ie fixin to get onto mazdabscene)
Cusser's avatar
Cusser
I'm a Yank, from Pittsburgh. I can only help with questions I can understand, kind of funny that way....
chrismp91
Thanks man u all realy helped me out lol
kia swap
last post by Brody +1y
51
