Mazda Engine General \  fuel filter with air bubbles????????
views 716
replies 3
chrismp91   +1y
ok so my fuel filter fills up full everytime i drive my truck and runs fine no isues....well we had to replace my gas tank due to a rust spot leak.....sence then my filter dosent fill up and gets alot of air bubbles in it but the truck runs normal and i checked all my hose clamps and the fuel system on top of the tank but its all tight and no leaks....i also removed the check and cut valve thing that use to hook to the canaster cause i have a weber setup....are thes bubbles a serious isue and why am i getting them now?
Cusser   +1y
I wouldn't worry about it. On my B2200, also with Weber, I have absolutely no idea if mine has bubbles or not !!!
chrismp91   +1y
well the filter im usin is a fram inline npt the plastic one they usuly have but ive tryed everything and maybe it was just that plastic check and air valve....idk somethings are a myst ery anymore
wageslaveescapist   +1y
To me, it sounds like you have a little air leak in the fuel system. Try spraying it with something and look for bubbling
