Help 90 B2200 Wont Run
julian
Hello, I have a 1990 Mazda b2200 fuel injected. It was idling in the driveway like normal, then it just died. I tried starting it up and it just wouldn't catch. I was spraying starting fluid thru it and it would start for about 2 seconds and die again. I looked at the fuel pump line and its pumping plenty of gas. all fuses are good it has gas, I don't know what it is.. please help. Thank you so much.
I
inlinesicks
If it starts on starting fluid the problem is fuel. Check your fuel pressure at the rail, you may have volume but not enough pressure.
X
xxchromeghostxx
or you could have clogged injectors from something that made it past your fuel filters ( it happens) and you could also have purchased watered down gas, idk about the rest of the areas but here even some of the big name gas stations have water in their tanks, they just refuse to clean them out until no one comes in, my sister worked at one here for 5 years and they finally got shutdown for the owners lack of cleaning water from the gas holding tanks. but just something to watch out for, even running no ethanol ( on some engines not saying is the case idk sorry i) can cause engines to run odd, or running ethanol in the gas, finding a place that sells 100% gasoline no ethanol maybe try that idk on these engines that paerticuliar part sorry just tossing you ideas buddy.
julian
ok. thanks. But the thing is while im spraying starting fluid it will just run for 2 seconds and die even if im still spraying the fluid. how would I figure out if its the injectors?
X
xxchromeghostxx
That i'm not sure about at all sorry, maybe someone else would be more helpfull, or search the thread topics in the 2.2 engine section see if this may been asked before?
spacemonkee23's avatar
spacemonkee23
This happened to me when my mass airflow sensor (MAF) died, or if the intake tube pops off of the throttle body area.
- Check the intake tube, make sure everything is tight and connected, no rips or holes in the tube, etc.
- (disconnect the battery) unplug the mass airflow sensor and try to clean the connector with some electrical cleaner. Possible corrosion in there.
- Replace the MAF if need be.
MAF will kill the motor if it is not reading properly. If you are short on time just unplug and plug it in a few times to see if it is corrosion. It's worth a try.
Hope this helps.
julian
thank you I will try that
kia swap
last post by Brody +1y
51
