Mazda Engine General \  swap 2.0 head to 2.2 head
views 1139
replies 4
following 2
b2200cjjr   +1y
Hi I am new to this forum.
I have a 87 B2200 that i put in a 2.0 motor in, now it blows white smoke and i am getting a little white on the inside of my oil filler cap.
I have a 87 2.2 head rebuilt and ready to go, the heads look the same the only thing i see different is the hyd lifters, and the head gasket on the 2.0 has a restrictor on the oil passage and the 2.2 gasket dont. Anyone have any info on this thanks.
sincitylocal   +1y
Use the 2.0 head gasket for the 2.0 block, or the 2.2 gasket for the 2.2 block. The 2.2 has a restrictor in the block.
The heads are the same. Use the mechanical rockers and cam for a quieter valve train.
b2200cjjr   +1y
Thanks for the info. if i use the 2.2 gasket without the restrictor could it possibly get more oil to the lifters?
sincitylocal   +1y
You'll run the risk of denying the bottom end of oil pressure.
b2200cjjr   +1y
Makes sense thank you for the info.
