Mazda Engine General \  Ignition trouble
Ignition trouble
views 2080
replies 14
following 5
maliciousmazda   +1y
K guys 91 b2600i. Does not start with key but can be jumped at the starter. Just checking if you guys know right off hand if it the ignition switch or not.
b2600bomber   +1y
automatic or manual?
Cusser   +1y
Sure sounds like electrical part of ignition switch. Make sure the small wire connector on the starter itself is clean (and connected)
maliciousmazda   +1y
Manuel no safety neutral switch And yes all connections are good
b2600bomber   +1y
is the switch on your clutch pedal unhooked?
maliciousmazda   +1y
Yea been like that for years
b2600bomber   +1y
here is a wiring diagram:
it is either the key switch or the wire going from the clutch switch to the starter... is there a jumper wire on the hooked plug?
maliciousmazda   +1y
No jump wire but I'll check everything out when I get back on land
b2600bomber   +1y
i had a s10 that wouldn't start unless it had a jumper on the plug i'll run out and check my truck in just a little bit and see if mazdas are the samek
kevinly   +1y
I have exact the same issue. Can you please let me know if you have it fixed? Thanks.
