Mazda Engine General \  leaking clutch master cylinder
views 525
replies 4
following 5
madaz_max   +1y
hey guys i am wondering if anyone has encountered this before on a b2600 '92' model, My clutch master cylinder is leaking down the firewall from the actuator housing. iv'e gotten another master cylinder from an old b2600 at the wreckers but I am wondering if just bleeding my lines to check for air bubbles will do the trick?
mymmeryloss   +1y
The m/c and slaves go out on these trucks all of the time
dan woodland   +1y
It would be a good idea to get a new one... you'd get a warranty and know it works.
ulrich   +1y
EDIT:" Duh you said 2600. IDK how different it will be.
It's wise to swapped master and slave together.
Here's my write up:
" target="_blank
You'll sill need the Haynes manual, as I only covered what Haynes don't.
Cusser   +1y
Agree: I always replace both now, have done this at least 5 times in the 20 years I've owned my B-truck.
I also suggest lifetime warranty cylinders, or dealer ones. Remember to bench bleed the new clutch master.
