Mazda Engine General \  Temperature gauge wire - 91 B2200 2BL
views 1108
replies 2
following 2
corysk8r   +1y
My temperature gauge on the instrument cluster is not moving. I checked the spot under the thermo housing and see the bullet-type connector there, exposed. The problem is I can't find the loose connector or even a loose wire anywhere that might be the one.
Anyone know what color wire the temperature gauge is coming off the instrument panel? I'm thinking I can just splice into somewhere near the firewall and run a new wire to the sensor on the thermo housing.
Any thoughts greatly appreciated!
Cory
scotch   +1y
Just spliced one back on last week, myself.
You should be looking for a yellow/white stripe wire. It should come out of the harness loom somewhere between the alternator and the bottom of the block. I used a bullet connecter for the connecter and it worked well. Not quite as snug as stock, but good enough.
corysk8r   +1y
Thanks for the help on this one. I got lucky and found the connector back behind the alternator.
Cory
