Power steering - 91 B2200
corysk8r
I need some general help troubleshooting power steering on my truck. Fluid level looks fine on it. I don't hear it making the whine I have come to recognize as a failing power steering pump. But, I am definitely getting a good arm workout driving it around town!
I also my 92 in the driveway that I can snag the pump off of if necessary (I think they're the same), but I want to make sure I'm not overlooking something simple first.
Thanks!
Cory
dan woodland's avatar
dan woodland
Hey Cory,
I assume your fluid isn't burned/is good, the pulley rotates as it should and you have a good belt adjusted properly. If the fluid is old/contaminated it may cause the pump not to work properly.
I don't recall ever hearing a PS pump on one of these trucks going bad. I'd make sure this one is really dead before you swap parts. You'll need to make sure the pump is actually pumping.
dan woodland
Try this....
corysk8r
Thanks for the tips . . . turns out I just needed to tighten the tensioner on the belt a little bit and I was back in business.
Cory
sincitylocal's avatar
sincitylocal
If you drove it for any length of time with the belt loose, it really should be replaced.
kia swap
last post by Brody +1y
51
