Mazda Engine General \  What could be causing this???
views 698
replies 3
b-t-s   +1y
Ok, I have a mazda B2600 that I have been having trouble with. I turned the key to "start" and when I turned the key off the starter kept cranking. I had the plugs pulled on the engine so it was turning over easy. I ended up pulling a battery cable off to get it to stop. Would this be the main relay? I pulled the main relay and took it apart and it looks fine?. My original problem was no spark, I just replaced the distributor because it was in bad shape. I tapped on the main relay and then I had spark and then the starter issue accorded.
Does anyone have any ideas?
Thanks
mymmeryloss   +1y
Sounds like an ignition problem to me
mazdatweaker_2   +1y
Sounds like you might need to take the starter off and have it tested. Maybe the solenoid is getting stuck.
sincitylocal   +1y
There is no relay between the ignition switch and the starter.
If battery voltage is low, the starter solenoid does not throw quick/hard enough, causing the contacts to weld together. The only other cause that I can think of would be the ignition switch is failing... which mymmeryloss alluded to.
