trans swap. drive shaft swap
8B
87 b2200
Hi I have not been on in awhile I have a question. I have a 87 and 86 one is a 2200 and the other is a2000 both 6' beds and regular cabs I want to swap the transmissions thay are both 5speeds one has a 2 piece shaft and the other has 1 piece shaft. Can l swap jest the transmission or will both drive shafts interchange
sincitylocal's avatar
sincitylocal
The transmission is the same. Either drive shaft will work with both transmissions.
8B
87 b2200
Any reason why the 2 different shafts
sincitylocal
We, the Mazda-B community, cannot seem to figure out why the trucks were done that way. There doesn't seem to be any rhyme or reason.
My guess is the two-piece(which tends to be a quieter setup) came in the LX models... but I really haven't based that assumption on actual comparison between models. I just know that two piece shafts are better at isolating noise/vibration.
kia swap
last post by Brody +1y
51
